Topics49,878
Posts837,745
Posts: 246 |
When we travel with suitcase, the existing 3rd brake light is obscured. So far, no issues (at least so far in CH, DE, NL, B, F & UK) but maybe we've been lucky. Reading various posts, I understand that if I remove the 3rd light, then that's legal, if I don't, and its fitted but cannot be seen, that's illegal. Is there any issue with securely fitting a flat Rain Light to my suitcase? Thanks
J. Neil
Posts: 490 |
The only issue I can see is that it costs £106. Try one of these, they are only there temporarily anyway, save a fortune and go and buy more wine. http://www.ebay.co.uk/itm/262290727199?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Peter
"Hasta la victoria siempre"
OXR 5 L - Learner Plates On
Posts: 209 |
"The only issue I can see is that it costs £106."
Exactly, Peter STUPID price for such an item!!
Tony
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Make a set of mirrors like a mini periscope to show the high? brake lamp over the case
Posts: 9,548 Likes: 132
Posts: 9,548 Likes: 132 |
Check DaveW " how to" threads. I am sure he showed how to fit a plug in temp light. There are definitely threads here showing versions.
Posts: 12,263 Likes: 320
Posts: 12,263 Likes: 320 |
I can't help thinking that something like this from Amazon is a bit more appropriate at less than 4 quid. I mounted mine on the lower rail of the luggage rack, where it can be seen regardless of whether luggage is being carried and so can be left in situ permanently:
Posts: 14 Likes: 1
Posts: 14 Likes: 1 |
Hammock
Where did you get the elegant clamp from ?
John Tinline 1997 + 4 Long door 4 seater (Now with Throttle bodies)
Posts: 246 |
Yes, it's expensive you buy one new.. but I have one off my old Caterham. The newer ones also flash, though my one, Lifeline, I think, is basic but should serve the purpose.
J. Neil
Posts: 1,502 |
I can't help thinking that something like this from Amazon is a bit more appropriate at less than 4 quid. I mounted mine on the lower rail of the luggage rack, where it can be seen regardless of whether luggage is being carried and so can be left in situ permanently: Surely that's not a "high level" brake light, though? Would it still be acceptable?
Posts: 246 |
I read somewhere 60 cm above std lights is EU law, though not sure if this is accurate.
J. Neil
