1 members (Saxonian), 164 guests, and 89 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#35545 04/10/09 08:14 PM
Does anyone know if you can get stainless bezels for the VDO instruments to replace the black ones??
Hi Morpheus,
You can get stainless bezels from Melvin Rutter. I fitted them to my VDO instruments. One thing I should say is that they were a little reluctant to sell them to me, saying that it was a job for a specialist. They did ship them, I fitted them (with no special tooling) and they look great in my opinion, just took a bit of time and patience.
Steve L.
1996 Plus 8
N22 MOG
I tried to attach a photo (which I've not tried to do on TalkMorgan before0 but it doesn't seem to have worked. I'd be happy to email it direct o.g. if you like.
Steve L.
1996 Plus 8
N22 MOG
Thank you. That would be helpful
email is cooke717 at btinternet.com
(edited to remove the @ or you could get junk mail from automatic 'spiders' that roam the internet looking for valid email addresses).
Hi N22
I would also be very interested in how you did this as I always understood that specialist equipment was required? The only person I could find to do it was Belmog, but he declined to deal with me as Jersey is outside the EU
The TM in Talk Morgan
Originally Posted By N22MOG
I tried to attach a photo (which I've not tried to do on TalkMorgan before) but it doesn't seem to have worked. I'd be happy to email it direct o.g. if you like.
Here is a link on the easiest ways to post a photo , if you get stuck you can also send me an e-mail and I will post it for you. smile
I've also tested the attachment to the post option (below) and it seems to be working fine - please let me know if you still cannot attach a file.
Test of attached file
Thanks, that worked beautifully.
Photo now on "latest photos".
Brian V, I prised the old bezels off from the rear of the instruments with a small screwdriver. On one or two of them I had to shave a tiny bit off of the rim to get the chrome bezel to fit, I used a Dremel fitted with a fine grinding stone to do that. With the instrument face down on a table and a piece of cloth I folded the new bezel over the rim of the instrument using the blade of a wide(ish) flat head screwdriver, slowly working around. The rear of the instruments probably don't look as tidy as if it had been done with a folding tool but once installed you can't see it anyway. I'm very happy with the finished article and defy anyone to tell that they weren't original or professionally done.
Steve L.
1996 Plus 8
N22 MOG
That would have made an excellent 'how to' post.
So if you do it again.................. grin2
Thanks for that N22
My '02 +8 has the later layout, I don't think the instruments are the same, my black bezels have a rather nasty D shaped extrusion at the bottom. I'm not to sure what I will find underneath if I pry them off. Hmm maybe time to talk to MK.
Brian
