Old Book
Topics49,940
Posts838,610
Posts: 27,864 Likes: 775
Posts: 27,864 Likes: 775 |
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Take the side screens off and go commando!!!!
Posts: 168 |
Topless and commando, the passenger side ballast would not approve.
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
Take the side screens off and go commando!!!! Are they the things I have in a case in the luggage rack?
BobtheTrain, Yep, they are the very items. Note to self, " Check to see that they are still there in the bag"
Clock, Beware the passenger side ballast, they have a nasty habit of reacting when questioned about levels of comfort.
Posts: 228 |
Apologies for opening this thread again but I'm still learning/looking for the many fixes required to keep a Morgan nice.
Clearly this chafing issue is a issue and I've seen some of threads regarding bonnet and door fixes; I have a little work to do there.
However I've now turned my attention to the door screens. I've again seen a few ideas but I'm wondering if anyone has simply applied Vaseline where the screens contact the door and possibly the tub. I can't imagine there would be to much of a issue providing the its kept clean and replaced if dirty. I agree protection film might be a good idea on the tub as its more likely to get dirty and rub. Any thoughts?
Andy
2011, 4/4, 2.0, 75th Anniversary 2016, VW Polo GTI 2012, BMW 520d Touring
Posts: 22,387 Likes: 359
Posts: 22,387 Likes: 359 |
Vaseline is fine on the bonnet tapes but it will collect dust and soon turn into an abrasive paste. It deposits black marks on the inside of the bonnet with an element of abrasion but not too bad. I've used a mix of leather, neoprene and paint protector film, depending on the location after trying various permutations!
Posts: 228 |
Thanks Dave.
Probably a daft question but do you think dirt would get between the screen padding and door once fixed into place?
Andy
I would think so. I use protector film where it rubs.
Posts: 2,784 Likes: 6
Posts: 2,784 Likes: 6 |
I would think so. I use protector film where it rubs. Ditto.. And if you use the right polishes so the edge of the film doesn't go white it's pretty much invisible. Better than Vaseline I would say.
Steve 2008 4/4 1.8 Duratec
