6 members (Graham, G4FUJ, ScotiaSteve, Image, Alan Patterson, Sir Percival, sewin),
227
63
Topics49,863
Posts837,561
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
Worked on a friends 89 Plus 8 yesterday. He had a long punch list. Fixed what we could but there were a few things beyond my abilities to correct. He needs to have his offside Armstrong shock rebuilt. Leaking badly and his car dies at a light or stop. My guess was the ECU? Rebuild as well. Thoughts??
After a day a mucking about with grease, we took the 89 Plus 8 and my 86 Plus 8 out to a pub for dinner and a pint. About a 10 mile drive.
Cheers,
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Posts: 463 |
Dave 98 +8 Corsa Red 74 MGB Red
Hi Dave, yes I do enjoy a day in the garage!! And always better with friends!
Cheers, Mark
Mark
Posts: 12 |
Hi, the stalling at stop was a feature of a 93 Discovery I had some years ago. It was a 3.5 but don't know which type of EFI it had. The problem turned out to be a faulty vacuum canister/diaphragm on the distributor.
Posts: 4,896 |
Worked on a friends 89 Plus 8 yesterday. He had a long punch list. Fixed what we could but there were a few things beyond my abilities to correct. He needs to have his offside Armstrong shock rebuilt. Leaking badly and his car dies at a light or stop. My guess was the ECU? Rebuild as well. Thoughts?? . , ECU not likely IMH, more likely to be the stepper motor on the flap valve that controls the air coming into the engine. The stepper has 100 segments and these can get dirty and give voltage miss-readings, then the ECU does not know where the throttle position is. When no throttle it needs to be 3.5v, if I recall correctly. Initially I would remove and clean with electrical contact spray, refit making sure voltage at closed is correct. Hope this helps.
Adrian
Good thoughts!! Thanks,
Cheers,
Mark
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
Posts: 2,361 |
From experience on running a clas b v8, I would simply remove the idle control valve and give it a good clean with carb cleaner
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 30 |
Tom.G.
2008 Aero 8 S4 auto. Grey 1960 Greeves 1957 Ariel Sq Four
Posts: 4,896 |
Worked on a friends 89 Plus 8 yesterday. He had a long punch list. Fixed what we could but there were a few things beyond my abilities to correct. He needs to have his offside Armstrong shock rebuilt. Leaking badly and his car dies at a light or stop. My guess was the ECU? Rebuild as well. Thoughts?? . , ECU not likely IMH, more likely to be the stepper motor on the flap valve that controls the air coming into the engine. The stepper has 100 segments and these can get dirty and give voltage miss-readings, then the ECU does not know where the throttle position is. When no throttle it needs to be 3.5v, if I recall correctly. Initially I would remove and clean with electrical contact spray, refit making sure voltage at closed is correct. Hope this helps. Wrong voltage I think it's 0.3v at idle, check it out to be sure.
Adrian
