10 members (britmog, Dada, Rex_tulips, John Winn, Alan Patterson, david nathan, Graham, G4FUJ, BobtheTrain, Gordon D, sewin),
292
38
SORN
New
Topics48,367
Posts813,393
Members9,215
Posts: 2,776 Likes: 59
Posts: 2,776 Likes: 59 |
Good write up - hadn't thought of tying off the wrap and winding the header towards it. It's amazing just how easy it is to take off and replace the headers after you've done it for the first time though. As for the cats; I'll be leaving mine in but if I manage to acquire a set of headers that don't have them so that there can be an annual swap for the MOT then...
Posts: 2,539 |
Hypothetically i wonder what size hole saws?
Posts: 1,490 |
Done quite a few wraps. Never heard of or considered removing the headers to accomplish it.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 2,539 |
Done quite a few wraps. Never heard of or considered removing the headers to accomplish it. I think they were off to pull the cats, and once off, why not wrap them without the suspension in the way?
Posts: 3,660 Likes: 48
Posts: 3,660 Likes: 48 |
As a matter of interest, as one or two people have commented, once our cars are three years old, they have to have an annual inspection, which includes a strict emissions test. However, once the test is completed, it is very unlikely that the car will get pulled over for another 12 months, and if the owner has substituted a cat. free pipe, no one would know! Great post and the dragon looks an awesome bit of road. For info, a 3 wheeler does not require a UK MOT emissions test - confirmed by Andymot (our "tame" MOT tester) with a link to the MOT regulations in another thread.
Red Leader
Posts: 1,490 |
Done quite a few wraps. Never heard of or considered removing the headers to accomplish it. I think they were off to pull the cats, and once off, why not wrap them without the suspension in the way? I would agree but that's not what he said.
Posts: 265 |
I realize this is an old thread. But I'm curious if removal of the cats and baffles plus the addition of a less restrictive intake, a) essentially results in a 'MMC Stage 1' upgrade, b) if it requires an ECU tune or does the (US-spec) ECU have enough bandwidth to adapt, and c) if a G56 Stage 2 upgrade that includes an ECU tune would be happy layering on top of the 'homemade' Stage 1.
Asked another way, would this mod save the cost of a Stage 1, particularly if the goal is Stage 2 anyway?
'17 M3W: '08 Ural Gear-Up
Posts: 902 |
Don't you need the Cam upgrade to accomplish this?
There's a bit of inconsistency in the stages depending on whether you are talking MMC, G56 or Krazy Horse. Basically the standard ECU should be OK until you upgrade to the 569 cams.
MMC/G56:
Stage 1: Exhaust and air filter, fine with standard ECU Stage 2: Add upgraded cams and ECU
KH:
Stage 1: Exhaust and air filter, retain standard ECU Stage 2: Add ECU and dyno tune Stage 3: Add cams and dyno tune Stage 4: Add 128ci big bore kit, roller rockers, ported cylinder head, throttle bodies, high flow injectors and dyno tune
Red Leader
Posts: 265 |
Don't you need the Cam upgrade to accomplish this? Don't you need the Cam upgrade to accomplish this? Correct. Which includes an ECU reflashed for the cams, so wouldn't it assume the engine is breathing better too and factor that increased air flow into its equation? So if the goal is Stage 2, why not just help the engine breath better on your own? If the noise proves unacceptable, buy a set of Stage 1 pipes. Does this make sense? I'm trying to figure out why a MMC Stage 1 is worth $2k.....
