4 members (IcePack, Zach, Gordon D, MJF), 241 guests, and 65 robots.
+8Rich 76
Topics49,861
Posts837,532
Jonny72
If the prior owner used Dot 5 I would continue to use Dot 5. However, if not I would just Dot 4 and change the fluid every 2 years.
Button
Seattle - Cold and Wet
Button
My argument is not if Dot III, IV is better or worse than Dot 5. It is a PITA to change hydraulic fluids back and forth.
Button
Seattle
Button
Drive on the Wild Side
Dot 4 is commonly used in many cars and more than adequate for a Sunday driver. Brake fluids absorb water with time, part of the reason rear brake cylinders cease up on Morgans. Brake fluid should be flushed through and replaced at least every 2 years, especially on a car that sits around in a garage not doing many miles. That's my view for what it's worth. grin2
Adrian
Do not change from one type to another without changing all the seals in the braking system. Using a different fluid (can't remember which way round now) can make the seals swell and makes for "interesting" braking issues.
Simon
Series 1 Aero 8
So it seems the majority favours DOT4. I have heard things about DOT5, but seems to relate to not being able to switch back and forth.
I think I will go with the majority and use DOT4. I will do a bit more research to confirm that DOT4 aligns with my expectation of the use the car will get.
Thanks to all for your input
