7 members (Doug J, Dek, MJF, TBM, Guern, Ian Wegg, Bunny),
210
79
Topics49,861
Posts837,531
Posts: 1,943 |
If the prior owner used Dot 5 I would continue to use Dot 5. However, if not I would just Dot 4 and change the fluid every 2 years.
Button Seattle - Cold and Wet
Button
Posts: 1,943 |
My argument is not if Dot III, IV is better or worse than Dot 5. It is a PITA to change hydraulic fluids back and forth.
Button Seattle
Button
Posts: 4,896 |
Dot 4 is commonly used in many cars and more than adequate for a Sunday driver. Brake fluids absorb water with time, part of the reason rear brake cylinders cease up on Morgans. Brake fluid should be flushed through and replaced at least every 2 years, especially on a car that sits around in a garage not doing many miles. That's my view for what it's worth.
Adrian
Posts: 844 |
Do not change from one type to another without changing all the seals in the braking system. Using a different fluid (can't remember which way round now) can make the seals swell and makes for "interesting" braking issues. Simon
Series 1 Aero 8
Posts: 27 |
So it seems the majority favours DOT4. I have heard things about DOT5, but seems to relate to not being able to switch back and forth.
I think I will go with the majority and use DOT4. I will do a bit more research to confirm that DOT4 aligns with my expectation of the use the car will get.
Thanks to all for your input
