3 members (Moggo, rossocorsa, Ian Wegg), 288 guests, and 81 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#378847 21/07/16 01:48 PM
Can anyone recommend a power steering system for a 1977 +8
Guernsey #378849 21/07/16 01:54 PM
I don't think there is one available, unless one was to convert to rack and pinion and go for the Jack Knight system?
Guernsey #378852 21/07/16 02:01 PM
Someone we know had one of these fitted to a Rover P4 with good results. No idea on Morgan fit.
http://simonebirchall.co.uk/shop.html
Costock, UK
Disco 5
Guernsey #378875 21/07/16 04:16 PM
Gerry
Guernsey #378927 21/07/16 07:36 PM
Your steering may be capable of improvement without immediate recourse to a power steering conversion.
The OEM steering box is a Cam Gears unit, check it has oil in it and that it is correctly adjusted with sufficient 'play' in the straight ahead position.
Have the tracking checked, it does make a difference and it will give the tyre place a good laugh when you quote the toe in fractions of an inch.
Fit Mulfab roller bearings under the main springs, it will lighten the steering effort.
If you have a steering wheel with smaller diameter than OEM or wider tyres, think again.
AND, different makes of tyre will impart totally different feelings in the steering.
All easily do-able, if you can get hold of a Gemmer steering box and brackets - do so.
Horror #379128 22/07/16 03:31 PM
"Fit Mulfab roller bearings under the main springs," I have radial (or ball) bearings made by Mulfab. Does Mulfab make something else?
Button
Seattle
Button
Guernsey #379143 22/07/16 04:13 PM
O
O
Hello Guernsey.
I have recently fitted my plus 8 with power steering. I favored the hydraulic system having looked at all the angles. and subsequently got one from John Southall of Classic Driving Developments. A significant factor for you is that the hydraulic system comes with a rack and pinion box, so with a few conversion bits your pointing in the right direction. Also by having a new rack as part of the kit the system enables higher geared steering, brilliant for sport,and you can get away with a small diameter wheel if needed.
Having power steering totally transforms the car I found I am now steering from the wrist rather than the arms and the knock back on rough roads, especially cornering has all but vanished. I am also impressed with the feel of the steering it feels much more direct than the electric version which I tried. If you are up for trials , solo or auto test then I think this is a brilliant up grade. Certainly helped me.
The fitting was a bit involved as you may have to remove a section of the inner wing with a hole saw and cutting disk but all in all it was OK The quality of the kit is outstanding and I for one am now a power steering convert
Obviously this is my personal opinion but I hope it helps.
Rog
Oxenhall #379869 25/07/16 04:52 PM
Originally Posted By Oxenhall
Hello Guernsey.
Question -
As a matter of interest, what did your conversion cost?
Rog
3.7 Roadster
Porsche 964 C2
JCW Mini Cooper S Cab
BMW F750GS
+4 4 1995-2002 / LM 62 +8 2002-07
Guernsey #379936 25/07/16 08:54 PM
Hi there,
We had our Roadster upgraded by Classic Driving Developments with the hydraulic version 2 years ago and absolutely love it.
We had the complete job done by them, didn't fancy taking on such a large task like this on my own.
Website details below:
http://www.classicdrivingdevelopment.co.uk/products.asp
Hope it helps.
Good luck
Terry
Frog-Mog, Roadster V6
Poor Old Larry, Defender 90
rid967 #379952 25/07/16 09:37 PM
O
O
The conversion was done here in my own workshop so no direct labour although i guess it should be about a day and a half. The kit from classic developments from memory was £2300 or so the costs are on there website.
Sounds expensive but in my case I needed to source a rack and pinion for a 1977 plus 4 steering upgrade, so the old removed rack saved me some money.
I noticed a comment added by Terrys he used the same supplier. Take a look at his comments I fully agree.
Cheers Oxenhall
Cheers
