7 members (Grumpy2, How, John V6, IcePack, DCH, MartinB60, Luddite),
337
43
Posts837,279
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Thanks boys! No immobiliser fitted. No smell of petrol or fuel pump noise therefore no power, no ignition light so no spark. Engine cranks over fine so starter motor getting power. 🤔
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Oh and the yellow battery light is on but turning over nicely....
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Has the inertia switch gone to off?
Posts: 932 Likes: 11
Posts: 932 Likes: 11 |
I just had (1 h ago ) the same problem on our 1990 +8. We find outit was the fuel pump relay. changed it an it works again.
colors of this relay wiring
white-purple white-orange braun white-slate bleu-purple
See GoMog
on my car, the yellow dashbordlith is from the inertia switch, it is burning when the red part of the switch is out
stefan
Posts: 5,587 |
Thanks boys! No immobiliser fitted. No smell of petrol or fuel pump noise therefore no power, no ignition light so no spark. Engine cranks over fine so starter motor getting power. 🤔 Does sound like fuel related ie fuel pump relay/fuse/fuel pump.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
A squirt of quick start in the air intake whilst turning over is a rapid fuel diagnosis - if it starts then it's a fuel problem if it doesn't then the likely hood is ignition.
Very useful diagnosis in a can!
I checked all the fuses today plus coil and alternator connections all ok but found a blown 10amp fuse in a live feed from the battery master switch. Replaced but all that did was bring the map light on and the 'check engine' light on.I now have the battery light and check engine light on but no ignition light hence non start. Connected my OBD reader but that won't work because ignition won't come on! I persevere...........
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
I guess a question is what tripped to blow that fuse? Do you have a wiring diagram you could work that out from? If not you might find it here.
Richard 1976 4/4 4 Seater
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Did this issue get resolved?
+8 4.8
No! I'm going to check the relays this weekend hopefully, everything else seems ok, will post results!
