1 members (Alastair), 314 guests, and 28 robots.
+8Rich 94
Posts837,276
Taffmog #380077 26/07/16 12:02 PM
Taffmog Offline OP
Thanks boys! No immobiliser fitted. No smell of petrol or fuel pump noise therefore no power, no ignition light so no spark. Engine cranks over fine so starter motor getting power. 🤔
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Taffmog #380082 26/07/16 12:11 PM
Taffmog Offline OP
Oh and the yellow battery light is on but turning over nicely....
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Taffmog #380107 26/07/16 02:38 PM
Ray Offline
Has the inertia switch gone to off?
Taffmog #380145 26/07/16 05:17 PM
I just had (1 h ago ) the same problem on our 1990 +8.
We find outit was the fuel pump relay. changed it an it works again.
colors of this relay wiring
white-purple
white-orange
braun
white-slate
bleu-purple
See GoMog
on my car, the yellow dashbordlith is from the inertia switch, it is burning when the red part of the switch is out
stefan
Taffmog #380156 26/07/16 05:54 PM
Does sound like fuel related ie fuel pump relay/fuse/fuel pump.
Taffmog #380430 27/07/16 05:29 PM
A squirt of quick start in the air intake whilst turning over is a rapid fuel diagnosis - if it starts then it's a fuel problem if it doesn't then the likely hood is ignition.
Very useful diagnosis in a can!
Mark - No Longer driving
Taffmog #380501 27/07/16 09:41 PM
Taffmog Offline OP
I checked all the fuses today plus coil and alternator connections all ok but found a blown 10amp fuse in a live feed from the battery master switch. Replaced but all that did was bring the map light on and the 'check engine' light on.I now have the battery light and check engine light on but no ignition light hence non start. Connected my OBD reader but that won't work because ignition won't come on! I persevere...........
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Taffmog #380535 27/07/16 11:02 PM
I guess a question is what tripped to blow that fuse? Do you have a wiring diagram you could work that out from?
If not you might find it here.
Taffmog #387767 24/08/16 10:51 AM
Did this issue get resolved?
+8 4.8
Taffmog #387987 24/08/16 10:56 PM
Taffmog Offline OP
No! I'm going to check the relays this weekend hopefully, everything else seems ok, will post results!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
