Topics49,861
Posts837,540
Posts: 115 |
To be honest, I would go for one of the higher-spec models, although they're a bit more expensive I find the recondition and supply modes to be very useful. Something like the MXS 5.0 would be very good. +1
David Monterey Blue +4 2010
Posts: 412 |
My, now rather old, Optimate works for me....at least 10 years old and going strong.
'di te incolumem custodiant'
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Just purchased a C-TEK last week only problem is the wires out of it are not very long compared with the Airflow I have had for years it gave up the ghost . Yes I know C TEK do an extension but its only 2.5m and I don't want wires across the bonnet . They should do a 5m one, a case of several cars in a large garage none close to plugs and you are snookered .
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
I use mine like a plug in: it's wired to the battery with the lead through the saddle board, so when I come back from a drive I just plug it straight into the mains via an extension cable.Battery still good afyer seven years.
GaB
Unregistered
GaB
Unregistered
At the risk of repeating the obvious, it's a CTEK XS 0.8 for me. I have had one for a year now, and use the cigar(?) socket. Excellent purchase.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
CTEK. I use the direct to battery connector that came with it as the powerciggy socket connection is a bit loose and occasionally poor connection. My battery is under the bonnet so no need for leads from the rear axle mounted locations.
Posts: 1,398 Likes: 258
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,398 Likes: 258 |
Posts: 7,363 |
Another vote for CTEK, excellent product. Also supplied as standard equipment with the McLaren so it meet's Ron's high standards too!
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
I have a pair of Optimates, nothing beats them imo. They even save some older batteries 👍
Aero 8 GTN #11
Posts: 112 |
CTEK x2 here also (Multi XS 3600). No problems for many, many years.
On the Morgan the connection is directly across the battery, via a Bulgin 2-pin panel mounting plug that a previous owner thoughtfully installed just behind the driver's seat. If you're out there and reading this - well done!
