Posts837,985
Posts: 128 |
In talking to the dealership, apparently the actual specification for drive belt tension is 50 Hz. You tap it with a hammer and use a device to measure how much it vibrates after that. Uh--not a device I've seen in the U.S.
Another way is to set it just tight enough you can just barely turn it 90 degrees.
Yet most belts are set using an offset measurement at the center of the belt. For example, when set properly, you might be able to deflect a belt 13mm when pressing on it between the two pulleys.
I'm reasonably comfortable with estimating "tight enough" but would welcome if anyone has a more precise, repeatable measure of appropriate tension.
Posts: 902 |
I have owwed several cars in the past that have had timing belts. The test has always been a 90deg twist along the longest length. That should be fine.
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
There is quite s bit of chat on this matter at the link below. Mark Evans from the factory involved with his take on how to.
Re: Bevel Box Noise Survey. Page 14
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
This is similar to what they use at the factory to set the belt tension: http://www.gates.com/products/industrial...and-accessoriesIt does seem to result in quite a tight belt at 50Hz and I run mine slacker than this, about 20mm deflection in the belt.
Posts: 128 |
20mm seems like a good idea. I've encountered many smaller belts that use 15mm. 20mm seems tight enough, yet conservative to protect the bearings.
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
I have owwed several cars in the past that have had timing belts. The test has always been a 90deg twist along the longest length. That should be fine. Mine was factory set and checked by dealer to 30° twist. Still the same after 2000+ miles.
Posts: 128 |
Thanks. I've got the feeling that there is a reasonably broad range of acceptable tensions between too tight and too loose.
Posts: 1,947 |
The Morgan PDI form says "Drive belt tension (1/4 of a turn) & clear of the tyre". That was 2013 & recommendation may have changed since.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Supermax recommend not to over tighten, if it doesn't slip a tooth it's ok. Mine has about 20mmm deflection.
