Topics48,379
Posts813,562
Members9,215
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
I think I read some where on TM that someone had packed thier grease gun for a European tour. What's the consensus gentlemen, surely our steeds are capable of a couple of weeks in Europe covering about 3k miles without attention to the knee joints My opinion (after 10 trips to Europe in my 4/4) is the intervals for greasing depends on conditions. Dusty or wet conditions require more frequent attention. I would always re-grease after a very wet drive. I also carry a small can of motorcycle chain-lube for the rear springs and a tube of copper-slip for the steering damper blades. OCD? I don't think so, as Stanley is close to 40,000 miles and still on original (and good condition) kingpins
Bud 4/4 "Stanley"
Posts: 6,830 Likes: 59
Posts: 6,830 Likes: 59 |
" The more you grease the less you wear!" As the actress said to the bishop.
Posts: 5,210 |
I like a couple of pumps whilst I'm in the sunshine.. Does Jays know that? He might need to be pre warned on your way to Caramulo!
Posts: 26,770 Likes: 429
Posts: 26,770 Likes: 429 |
My car has Devol bushes so can handle 5K supposedly. I just tested in UK 2 k & it was fine. Otherwise 1 k for me.
I will resist comments about Mr Strides ability to pump.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
I think I read some where on TM that someone had packed thier grease gun for a European tour. What's the consensus gentlemen, surely our steeds are capable of a couple of weeks in Europe covering about 3k miles without attention to the knee joints My opinion (after 10 trips to Europe in my 4/4) is the intervals for greasing depends on conditions. Dusty or wet conditions require more frequent attention. I would always re-grease after a very wet drive. I also carry a small can of motorcycle chain-lube for the rear springs and a tube of copper-slip for the steering damper blades. OCD? I don't think so, as Stanley is close to 40,000 miles and still on original (and good condition) kingpins That's good advice I think.
Posts: 14,009 |
I'll NOT be pumping whilst away on the Caramulo trip!
Posts: 5,210 |
I'll NOT be pumping whilst away on the Caramulo trip! I think Steve might pump for you?!
Posts: 1,943 |
I recently dis assembled a 2000 +8 with about 50,000 miles. Morgan owned by a Lady who lives in Sun Valley, Idaho. Her mechanic maintains the +8 and greases prior to any trips She takes. She will often ship Her Morgan to the location She will tour in and ship it back home. She never, ever greased the King Pins while on a trip. Her trips are sometimes a month long. These were mild steel king pins and bronze bushes. There was so little wear that I merely swapped the bottom bush for the top and reassembled. NO Gaiters.
Button Seattle
Button
Posts: 14,723 Likes: 151
Posts: 14,723 Likes: 151 |
I have been greasing my kingpins before and after every long trip. I have had trips as long as 4,000km without greasing the kingpins. The original factory bushes and kingpins needed to be replaced at 45,000km, somewhat to my surprise.
I now have hard chromed kingpins and hope that they will last a bit longer.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
I wouldn't consider greasing kingpins when out on a tour. Like Peter I do them before we set off and when we get back. The acid test is how long the new car pins last because I inherited the previous two without knowing kingpin history.
