Topics49,859
Posts837,470
Posts: 797 |
Posts: 2,539 |
Posts: 50 |
Over the weekend I jacked my car up and inspected the fuel lines umder the car without any findings. Further troubleshooting is now performed by the next Morgan service station. I am really curious what will be the result. I hope they will be able to fix the problem in time for the Grindelwald meeting.
M3W willow green,Triumph T100,KTM LC4 Adv./Freer.250R, RD250/RS125DX, Alpine A110 Kurt
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
The fuel pressure regulator is I believe built into the fuel filter, that is why it is relatively expensive for a filter.
Posts: 541 |
Over the weekend I jacked my car up and inspected the fuel lines umder the car without any findings. Further troubleshooting is now performed by the next Morgan service station. I am really curious what will be the result. I hope they will be able to fix the problem in time for the Grindelwald meeting. Please post the dealer's findings as I'm having the same issue with my car. Thanks, Timothy
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
Posts: 541 |
I just got off the phone with Tom at S&S Cycle Technical Support department. He told me the operation of the fuel injection system needs 60PSI fuel pressure at the motor at all times and should stay their minutes after you shut the motor off.
I'm only getting 50 then it drops to 40 at the motor. So I'm thinking fuel pump or a fuel pressure regulator issue.
Posts: 50 |
Hi Timothy Thx a lot for posting your informations from S&S technical support. That is in deed helpful as well. Just 5 min ago I got response from Abt Automobile (swiss Morgan importer) who finished his investigations with a clear result. The ECU turned out to be defective. The engine was running as normal after they swapped the ECU against another one from a different car for testing purposes. That check was one I clearly could not perform in my garage at home.
Posts: 50 |
My Threewheeler is luckily back on the road. With a new ECU in place the vehicle is now running excellent. All mentioned effects are wiped away. Grindelwald I am coming :-)
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 400 |
Wunderbar! Herzliche Glückwünsche!
Gute Reise!
M3W, now!!!
