3 members (aerotaff, simon8201, +8Rich), 191 guests, and 46 robots.
+8Rich 90
Luddite 50
Posts837,961
#390365 04/09/16 08:13 AM
Hi all, silly question time, I am replacing the indicator lenses on my roadster and im buggered if I can get the damned screws to align with the brass widgets that they screw into, is there a trick to this, I have been on with this 10 minute job for 3 hours and the lenses are about to become ..... abused
Volvo XC60 x2
Volvo C30
2010 Roadster
2001 Triumph Thunderbird
Front or rear? If you change the rears you need longer screws.
front
Volvo XC60 x2
Volvo C30
2010 Roadster
Is there a little notch of plastic that aligns in the slot as on the originals? If so make sure the two bits slot together.
Mark - No Longer driving
yes there is ,done that, the problem is that the brass widgets which the installation screws, screw into, are not fixed in position.
Volvo XC60 x2
Volvo C30
2010 Roadster
Oh? I had mine apart other day to drain one out! maybe the square threaded bit had corroded into place?
I glue them brass widgets into position with evo stick
me too;usually use a little 'Sikaflex' .
It's the best way to stop the little bu**ers moving 'till the screw gets a grip...... mad
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
I understand fully
confused2 swear banghead mad2 ranting stars crazy3
Yes they are only press fit and will do exactly as above.
Stick or better seal them in.
Also put a collar around the wire contact to stop it pulling through the fibre disc while you are at it.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
