14 members (Andy, Laurens, Zach, vincentvg, Bishmog, simon8201, +8Rich, riri, chanteclair, Mark+4, philandcolinsmor, JohnHarris, TBM, Haggispeed),
265
Posts837,976
Posts: 78 |
Hi all, silly question time, I am replacing the indicator lenses on my roadster and im buggered if I can get the damned screws to align with the brass widgets that they screw into, is there a trick to this, I have been on with this 10 minute job for 3 hours and the lenses are about to become ..... abused
Volvo XC60 x2 Volvo C30 2010 Roadster 2001 Triumph Thunderbird
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Front or rear? If you change the rears you need longer screws.
Posts: 78 |
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Is there a little notch of plastic that aligns in the slot as on the originals? If so make sure the two bits slot together.
Posts: 78 |
yes there is ,done that, the problem is that the brass widgets which the installation screws, screw into, are not fixed in position.
Oh? I had mine apart other day to drain one out! maybe the square threaded bit had corroded into place?
Posts: 27,835 Likes: 758
Posts: 27,835 Likes: 758 |
I glue them brass widgets into position with evo stick
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
I glue them brass widgets into position with evo stick me too;usually use a little 'Sikaflex' .It's the best way to stop the little bu**ers moving 'till the screw gets a grip...... James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Posts: 517 |
Yes they are only press fit and will do exactly as above. Stick or better seal them in. Also put a collar around the wire contact to stop it pulling through the fibre disc while you are at it.
Titus
2007 +4 4 seater 2017 Mini Cooper 2007 VW Camper 1996 Honda TRX300 2012 Husqvarna 216
