4 members (Mike D, Fuel.inj, Vansrv6, bmgermany), 157 guests, and 74 robots.
+8Rich 77
Topics49,870
Posts837,669
Rudolf
Just completed putting in new floor boards and a heat shield on my 1965 Morgan plus4 2 seater PM if you want to know how I did it
where did you place the heat shields? Are they for exhaust heat, protecting the electrics?
it was installed on the inside firewall the side walls transmission cover and the small driveshaft cover this is what I used
https://www.summitracing.com/parts/the-1...CFUdZhgod4FsHLw
simple to install kind of like hanging wallpaper it's self adhesive you need at 6 feet maybe more
One of the most extreme heat generators on a '60's +4 is the muffler. It is on the right side (In US Passenger side). In order to keep Mrs. Button as comfortable as possible I fitted a sheet metal heat shield over the top of the muffler. I did this by cutting (with My angle grinder) a metal pipe in half. It was a bit larger than the glass pak I was using as a muffler. I had the "Muffler Guy" weld it into place. It worked for years, but seems the weld caused the muffler to fail. So I must find a better way to attach it in the future. Winter project.
Button
Button
Thanks for the tip. I'm going to order this material today. I threw away the original insulation on my trans tunnel and now the leather gets so hot on a summer day that I'm worried about it.
1961 +4 Four seater
"Crude, but effective."
It's not difficult but the material is very sticky when you peel away the backing, I did my trans cover when it was out of the car, much easier on the trans cover just cover the entire cover then cut out the holes with a razor blade
