0 members (),
303
91
Topics49,847
Posts837,389
F182CGJ Just Getting Started
Posts: 31 |
Apologies if this subject has appeared elsewhere (sure it has) - but I can't find a solution to the problem. 1987 Morgan 4/4 (147000 miles) rear springs replaced with 6 leaf springs about 8 years ago (Mike Duncan); horrendous metal against metal noise from rear near side when hitting a recession in the road (but not a bump). Checked all the nuts/bolts and that the spring harnesses are free and lubricated. Not exhaust nor brake related (so far as I can tell). I guess the issue with a recession in the road is that the wheel/axle has to descend before being thrown upwards when coming out of it - so effectively having to travel twice the distance of hitting a 'normal' bump? No-one (neither Mike nor the local garage) can trace the source.
John Humphreys
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Have you removed the rear near side shock absorber and checked what happens when you operate it through a full movement cycle?
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
U-Bolts not over long on the inside where they sit over the chassis ?
Is it metal - metal squeak or metal - wood as I am thinking possibly anti tramp rubbing on the cut out in the panel behind the seat (if yours is done that way)
Posts: 288 |
Don't think there will be an anti tramp on that car. Check bracket that shocks are mounted on behind the rear brake drum, they have been known to break.
Posts: 31 |
Thanks guys - will check all these possibilities.
John Humphreys
