11 members (Graham, G4FUJ, High Hamster, DCH, Montegue, JamesS, MartO, Joske Vermeule, TeddyAds, sewin, cerealsurfer, BLUE+4),
307
64
Topics49,860
Posts837,522
Posts: 94 |
My 2005 4/4 has a tyre size 165/80 15 and it´s Vredestein t-trac 2 new tyres. My Front Suspension are upgraded to Mulfab Hard Chrome Kingpins, over-size Phosphor Bronze kingpin bushes, Steering Bearing kit, Steering Damper and SPAX Adjustable Dampers.
The Morgan Owner´s Handbook says that the tyres should be set at 22 PSI. My car do a kind of floating on the road with only 22 PSI. Now I use 26 at front and 28 at back, and the car is very nice to drive. The damper has 1 click.
I have tried with different hardnes on the Spax damper and find hat 1 click is the best.
The car are 1130 kg (2491 lbs.) with 2 person and traveling equipment.
What experience do you have with the tyre pressures and dampers adjustment?
----------- 2005 4/4.
Posts: 1,943 |
I have 3 Morgans, all old, I use 24PSI all around on all of them. I have tried different pressures on all of them. 22 too low. I think if I had My druthers I would run at about 28PSI. 24 seems about as good as it gets with Me and keeps My passenger a bit happier.
As for shocks, take them off and try that. You will be amazed at how little they do. I have Koni's on the softest setting. Mainly to keep My fellow Morgan Owners from laughing at Me.
Button
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Your pressures sound about right. Factory pressures do seem a bit low. Experiment and find out what's right for you. Agree with Spax, use on softest setting especially if they are the older type. Konis are a bit more compliant.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 94 |
Posts: 94 |
Thank you! I will check and try a bit more. With and without load (wife and suitcase).
Posts: 987 |
Always found the best ride in my mogs has been at 22 psi all round.
Posts: 1,104 Likes: 17
Posts: 1,104 Likes: 17 |
What about tyre pressures on a roadster 4 seater with +8 alloys?
