1 members (Alan Patterson), 310 guests, and 87 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,427
#395847 29/09/16 05:34 PM
JVS Offline OP
I have a friend who races Miata's and sent this to me.
I haven't checked it out yet but want to share.
http://revlimiter.net/blog/2014/10/parts-review-miataroadster-short-shift-kit/
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
It may work if you have the earlier rear mounted shifter but the later forward mounted shifter has a very rearward bent arm.
I posted photos....
http://www.talkmorgan.com/ubbthreads.php/topics/392947/Re:_Short_Shifter#Post392947
kirkusblog.com
1952 Ford 8N
Wouldn't work for me as if the length of the gear shaft is 3" longer than standard the gear knob would be well above the lower edge of the dashboard of a Morgan and smashing my hand on the dash when changing into 1st, 3rd or 5th gear isn't a change that I would welcome.
Andrew
'Alice' 2013 Duratec Plus 4. Pearl Blue
You could shorten the lever Andrew255 but it will make the change heavier, why bother? The Mazda forward gearchange on the M3W is as near perfect as you can get anyway. These long lever, short shifts are designed to make the top of the gear lever closer to the steering wheel for quick changes on a Mazda MX5/Miata, not a problem on a M3W.
+1
1998 +8
SS Sport tuned exhaust
2013 M3W
Stage ll motor kit
Cats removed
