11 members (jejemek, IcePack, Baristas, vincentvg, aerotaff, Image, Vansrv6, Alan Patterson, Ritchie B, Ncik P, BLUE+4),
323
78
Topics49,851
Posts837,443
Posts: 2,539 |
It may work if you have the earlier rear mounted shifter but the later forward mounted shifter has a very rearward bent arm. I posted photos.... http://www.talkmorgan.com/ubbthreads.php/topics/392947/Re:_Short_Shifter#Post392947
Posts: 565 Likes: 8
Posts: 565 Likes: 8 |
Wouldn't work for me as if the length of the gear shaft is 3" longer than standard the gear knob would be well above the lower edge of the dashboard of a Morgan and smashing my hand on the dash when changing into 1st, 3rd or 5th gear isn't a change that I would welcome.
Andrew 'Alice' 2013 Duratec Plus 4. Pearl Blue
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
You could shorten the lever Andrew255 but it will make the change heavier, why bother? The Mazda forward gearchange on the M3W is as near perfect as you can get anyway. These long lever, short shifts are designed to make the top of the gear lever closer to the steering wheel for quick changes on a Mazda MX5/Miata, not a problem on a M3W.
Posts: 541 |
+1
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
