7 members (Guern, Bunny, Dek, Ritchie B, Liam1961, DickJ, JohnHarris), 277 guests, and 76 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
#398290 08/10/16 06:36 PM
All
How much heat should I expect from my 4/4 heater put it on the other day and it was about as hot as someone breathing down my neck!!
So much not use now its turning colder. looks like I'm gong to have to buy a leather aviator jacket soon.
Mine is the other way round.
The footwell get to hot I have diconnected the hose to the heater.!
Maybe your heater core is partially blocked- try disconnecting the hoses and flushing through with the garden hose. You may need to top up the anti-freeze afterwards. cloud9
Gerry
E
E
Or maybe an air lock or a disconected water valve wire.
Check the cables on my 97 +4 the cable moved a flap to allow hot or cold air in, you. As discussed flush the core. I had a Renault 5 TS once that was full of sludge in the heater core.
It should be a very effective heater.
Lucky B., I can't even get mine to blow more than lukewarm ! Brrrrrrr.....
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
If I is any solace: the heating in my 1989 4/4 functions thanks to to both the phenomenons of capillarity & osmosis and produces a faint lukewarm sensation after 20 minutes driving...
owner of a 1989 4/4 2 seater, AKA "Bubbles"
Would "Bubbles" refer to a potential air lock in the heater?
All three of my Morgans ('76 4/4, '97 +4, '93 4/4) have had really good heaters...
According to my garagist (Garage Albert in Brussels, of good repute) there is no way in which to improve Bubbels' heating. But thanks for the suggestion all the same, Graham. I'll mention it to him.
A good flush might well solve the problem. My 89 Plus Four had an excellent heater too.
