0 members (),
331
89
Topics49,860
Posts837,485
Posts: 1,947 |
Kirk this will not be the last time, there will be plenty more little items requiring attention & sometimes big ones.
Tim
Posts: 371 |
Hmm.. so much for Morgans PDI. That obviously didn't happen in transit.
'16 M3W '44 Willys Jeep '16 Westfield 11
Posts: 2,539 |
So I worked on it for 30 minutes and driven 150 miles. That ratio is still better than almost any other car I've owned.
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Great pdi as usual by the looks of it. I lost rear reflector 2nd drive out!
Posts: 371 |
Great pdi as usual by the looks of it. I lost rear reflector 2nd drive out! Brilliant, can't wait to lose mine lol
Posts: 2,539 |
Today's Morgan fun fact! You know that black button at the end of the stalk, the one that is totally not mentioned anywhere in the owner's manual? If you hold it down you can get to a screen which allows you to adjust the illumination setting of the dashboard. Well not the whole dashboard, just the speedometer! The clock and the tachometer seem to only have one setting! Also on the new dashboard the speedometer and tach are illuminated in sort of an orange color, whereas the clock is just plain bright white.
Posts: 8,671 Likes: 408
Posts: 8,671 Likes: 408 |
On the cars with standard instruments, you long press the end of stalk in voltage display mode to gain access to illumination. It then adjusts speedo and tachometer.
Ye hate that yellowy orange might take mine out see if change to green or blue!
Posts: 2,539 |
Alright, I checked it this morning and even if set the cluster to monitor voltage first it's still only changes the illumination of the speedometer!
Posts: 1,490 |
Today's Morgan fun fact! You know that black button at the end of the stalk, the one that is totally not mentioned anywhere in the owner's manual? If you hold it down you can get to a screen which allows you to adjust the illumination setting of the dashboard. Well not the whole dashboard, just the speedometer! The clock and the tachometer seem to only have one setting! Also on the new dashboard the speedometer and tach are illuminated in sort of an orange color, whereas the clock is just plain bright white. Hmmmm... the button is mentioned in mine. And I had a thread about my speeding light being out. The dealer was ready to order a new gauge when they also discovered it's a single gauge adjustment. Makes no sense, right?
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
