5 members (vbalddave, JohnPlus8, Ritchie B, Image, Chris Cosher), 333 guests, and 40 robots.
Topics49,860
Posts837,486
Jonny72
Page 65 of 108 1 2 63 64 65 66 67 107 108
Kirk this will not be the last time, there will be plenty more little items requiring attention & sometimes big ones.
Tim
Hmm.. so much for Morgans PDI. That obviously didn't happen in transit.
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Draggin Offline OP
So I worked on it for 30 minutes and driven 150 miles. That ratio is still better than almost any other car I've owned.
kirkusblog.com
1952 Ford 8N
Great pdi as usual by the looks of it. I lost rear reflector 2nd drive out!
Brilliant, can't wait to lose mine lol
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Draggin Offline OP
Today's Morgan fun fact! You know that black button at the end of the stalk, the one that is totally not mentioned anywhere in the owner's manual? If you hold it down you can get to a screen which allows you to adjust the illumination setting of the dashboard. Well not the whole dashboard, just the speedometer! The clock and the tachometer seem to only have one setting! Also on the new dashboard the speedometer and tach are illuminated in sort of an orange color, whereas the clock is just plain bright white.
kirkusblog.com
1952 Ford 8N
On the cars with standard instruments, you long press the end of stalk in voltage display mode to gain access to illumination. It then adjusts speedo and tachometer.
Ye hate that yellowy orange might take mine out see if change to green or blue!
Draggin Offline OP
Alright, I checked it this morning and even if set the cluster to monitor voltage first it's still only changes the illumination of the speedometer!
kirkusblog.com
1952 Ford 8N
Hmmmm... the button is mentioned in mine. And I had a thread about my speeding light being out. The dealer was ready to order a new gauge when they also discovered it's a single gauge adjustment. Makes no sense, right?
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
