0 members (),
269
86
Topics49,847
Posts837,389
Posts: 513 Likes: 2
Posts: 513 Likes: 2 |
Well I was hoping to take delivery of my Plus 4 on Saturday. I noticed that the rev counter returned to 1000rpm, not 0, when I test drove it. Well the garage cannot seem to fix it. Just writing on here if this is a common issue??
.....still waiting :-(
Nick
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Nick, In my ownership of 3 +4s, my answer is no, it is not common however, on my SS100, which had an electric rev counter, if you didn't give it time to "do it's thing" and settle then it would really miss behave so perhaps it's a gremlin in the ECU. Is your car a GDI?, if so it may benefit from the upgrade flash which only takes a couple of mins. Good luck, hope you get it sorted.
Posts: 3,643 |
Nick, my rev counter does this. I used to fret about it, now all I do if I notice it is to switch the ignition on then off and the needle drops to zero. In my non expert mind it is as if the instrument does not Earth at shutdown. Really do not worry about it.
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
Happened in my 2014 4/4 today for the first time !!...turned ignition off then on and all is good.
Posts: 522 Likes: 1
Posts: 522 Likes: 1 |
Nick did you turn the car off??
Posts: 990 |
Yup i stalled my 4/4 once and it did that. Just turning Ign on and off again cleared it. no idea what caused it and its not happened since.
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 5,439 Likes: 131
Black Rat Charter Member
Posts: 5,439 Likes: 131 |
Starting the car before the immobiliser light goes out will cause this.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
If you tap the speedo or revcounter with the ignition off it will probably drop to six o'clock.
Don't use a hammer.
Posts: 3,643 |
Starting the car before the immobiliser light goes out will cause this. Hi Keith, not in my case. Also leaving the car ticking over before turning off makes no difference. DaveW, I have tried tapping glass, maybe not hard enough, no difference. It is the only 'funny' I have with the car.
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
Never good to tap "the glass" - the body or surround howwever is OK...
