8 members (Jon G4LJW, MATTMOG, Luddite, Tom Sayles, Hamwich, DCH, Davetherave, RedThree), 207 guests, and 126 robots.
+8Rich 78
Topics49,872
Posts837,687
Rudolf
Page 3 of 3 1 2 3
I have been looking at OMEX for some time. I have also researched MegaSquirt (even bought an ECU) as well as using motorcycle throttle bodies etc. etc. But, so far, have not been able to make a decision about increased performance. Also I am in a quandary about Original vs Throttle body.
My feeling is that the Ford ECU is primarily emission and MPG oriented while the OMEX is performance oriented. MegaSquirt will run the Fuel Injection system but "How Well?"
Button
Coupled with My Throttle Body quandary is "Variable Valve Timing" for us Ordinary Back Road Drivers.
Button
http://www.turbosport.co.uk/showthread.php?t=354531
Interesting information about ZETEC BHP/Torque in Fuel Injection engines as well as Weber DCOE's. Looks like the Webers have the "Edge". But suspect driveability of the Webers are not as good.
Button
Button,
My experience of fitting EFI to a Lotus Twink is this.
Power (BHP) gained (or lost) by fitting TB's vs Webers is zero.
Torque (FT/LB) gained from the ECU mapped ignition vs worn dizzy is lots.
Torque (FT/LB) gained from the ECU mapped ignition vs good dizzy is some.
Driveability gained from fitting EFI is lots.
MPG gained is about 4 mpg.
I would also add that any of the ECU's that give you the features that you want will perform well. The key is the person who does the mapping.
The best ECU poorly mapped will be crap and the worst ECU well mapped will be good.
Cheers
PS would love to fit TB's to my +4 when funds allow.
Originally Posted By John07
Button,
Cheers
Thanks! Which +4 do You have? If it is a Zetec or Duratec, why do You think a TB would improve the performance?
Button
Button,
I have a Duratec.
"why do You think a TB would improve the performance?"
Not quite sure what you mean by that. I was considering fitting the same kit as the OP fitted. That is 1 choke per cylinder vs Fords 1 choke for 4 cyls. It should give another 35 BHP (approx), but at higher RPM.
Yes I could fit a pair of Webers but I think using an ECU to control the engine is a good idea. To me the pros far out weigh the cons. Plus I have the emission laws to think of.
Cheers
Button,
I have a Duratec.
Cheers
The information I am getting (mainly from My friends in Seattle and not near as knowledgeable as the UK) is that there is NO increase in Torque/BHP (not so sure at a higher RPM), better engine response, but poorer driveability. 35 HP is certainly significant. I realize that You can not use the Weber DCOE in the UK due to emissions. But I can. I am using some sort of "Home Grown" computer to operate the ignition. But it only uses RPM to advance/retard the timing (about like a Dizzy without vacuum advance/retard). I did follow 2 TR powered +4's and struggled to keep up with them. Makes Me wonder!
Button
Button,
I have a Duratec.
Cheers
The Key seems to be "choke". I think I should be on a "Kit Car Forum" rather than "Talk Morgan". If any body has a good UK KC Forum please advise.
Button
Button,
My claims for my Lotus are just the results as I find them. As for your comment of "poorer driveablity" all I can say is that there must have been something wrong. The better driveability is one of the best things of the conversion. Also, to be fair it may depend on what carbs you have changed from. SU's in particular are good on the driveability front, but EFI should still be better.
The extra power from a 2l Duratec with TB's is only what Omex claim for their standard engine with TB's.
http://omextechnology.co.uk/Omex%20Duratec%20Engine%20v4_0.pdf
If, on your home made ignition you are not using the engine load as an input then you are missing a trick. With this you can run a lot more advance while cruising and still keep the engine from pinking while under heavy load. If building a new engine it will enable you to run a higher compression ratio.
A couple more links that may be interesting:
http://www.sbdev.co.uk/Parts%201_6L%20Catalogue.htm
http://www.emeraldm3d.com/articles/cat/knowledge-zone/
Cheers
Button,
Cheers
Thanks John; Maybe You will pull Me into the 21st Century. Lots of good information. This should keep Me busy for a bit.
Button
Page 3 of 3 1 2 3
