0 members (),
258
Topics49,844
Posts837,360
Posts: 400 |
Evening all, Ok have my pipes off doing a deep clean, have read a few threads on exhaust mods, whilst its off should I remove cat, drill a baffle, or nothing, trying to get the best breathing for the engine maybe a bit more noise but overall to avoid the pinking etc,she is runniing a garage 56 filter, was keen on any views here before I put her back together
Superdry 76 Fizzy
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
Drill the baffles! Your M3W will be thankful. The additional noise is something you get used to fery fast!
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
+1 It's the front one that makes the most difference.
Posts: 400 |
Thanks for the replys gentlemen, I know its a subject that lots think about and make different decesions on, but I'm a driller or will be tom!
Superdry 76 Fizzy
Posts: 2,539 |
I think im drilling just my front baffle in the spring. Leaving everything else be....
Posts: 306 |
Some more pictures of what people are using would be great. I've seen a couple threads describing it, but some photos would be awesome. I'd like to know what to take with me when I pick mine up in Illinois, cause I think I'd like to have that baffle removed for the drive back to Texas.
Posts: 1,947 |
Remind me please what size hole saw have folks used to drill the baffles. How far in is the front baffle? Mols excellent post does not specify dimensions.
Tim
I run my M3W with the factory stage 1 kit so no drilling fotos available.
When it comes to pure physics: drilling only one buffle plate does not make a lot of sense. Much better to drill both to fee the airflow. The larger the diameter the better the flow. I would not remove the cat as a first step but keep it as a last option for completely free pipes. If you are afraid of noise: you can always put a steel wool sponge or metal strech sheet into the rear end of your pipes for sound damping.
Tools required:
Vice 38mm hole cutter 18" long 3/8" extension bar with socket to fit the hole cutter Cordless drill with adaptor to fit the extension bar Tapping paste or lubricant Patience, it's stainless and tough. Take your time.
I wore out 2 cutters doing mine.
Posts: 400 |
Tools required:
Thank you very useful info
Superdry 76 Fizzy
