Posts837,278
Posts: 2,583 |
I picked up my new stainless wires(MWS) and tyres from Blockley tyres yesterday. A sticker on the wheels (noticed as I unloaded them) said to spray with wax before use - any suggestions as to a suitable wax for stainless wheels? Here`s a challenge to get your post in before Mr W!!!
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Odd as MWS's website ( here ) says no further care necessary.
Richard 1976 4/4 4 Seater
Posts: 6,538 |
Should not need any Phil- but a Halfords do a can of light bike spray.
Neil
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Got the very same on mine a few years ago tried several then picked up a bottle of that showroom shine , and it lasts . I cover the spline area and then spray the full wires both sides on all wheels . That way I have to clean it off end up with clean wires the wax gets into the nooks and crannies .
Posts: 6,538 |
I used some on the Inside edge of my Wires when i took them all off last Autumn to clean the debris etc - but just as a precautionary coating.
BTW I guess that the unseen inside edges had never been cleaned in 3+ years but they came up like new!!
Neil
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Only wax I can think of is tyre bead wax and that's used when you are fitting tyres. Usually applied with a brush though!
Arwyn
Posts: 28,888 Likes: 350
Posts: 28,888 Likes: 350 |
Why not ask MWS what they recommend Phil?
Posts: 168 |
My MWS wires had stickers on them saying how to look after them etc, unfortunately on three of my wheels the stickers were where the tyre rim seals against the rims. As a result I had three very very slow punctures, so probably worth checking.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I'm guessing the wax is only to help with cleaning -it will just stop a bit of brake dust clinging to the surface and give it a bit of protection and just make it easier to look great with a jet wash of water and very mild shampoo
There are two products that I think will be a good idea to apply as they are brand new before you drive and it's an either or as they don't work together
Auroglyms wheel protector spray -it's an aerosol spray clear protector that cures as it drys - last a few washes
Or (and this will be a real surprise to all regular TMers )
Meguiars Ultimate Quik Detailer -(gosh really I all hear you say)
But make sure you dry it off with a cloth as it drys streaky
This is hydrophobic so will help prevent water ingress down the spokes
Also has wax to give a bit of protection and shine
It won't last many washes but you could just keep on using that - it lifts brake dust superbly
If it was me with new wheels I'd put several coats of the stuff on leaving it to dry 20 minutes in between
But then I'm silly
Posts: 6,538 |
Good advice Stewart....not silly at all!
Neil
