9 members (Davetherave, jbk, nick w, Hamwich, John Winn, +8Rich, BobtheTrain, gazum, TalkMorgan), 366 guests, and 65 robots.
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,437
#430671 19/02/17 05:53 PM
I changed the fuel pump for the second time last week And after the Mtw started.
I try starting it today without succes.
There is fuel going out by the valve between cylinders but there is No fuel inside the cylinders .
What is the pump pressure?
If there is fuel coming out of the injectors then it could be the cam belt sprocket has worn and the cam timing has slipped. This is what happened to mine.
You can quickly check by seeing if the alignment holes are still OK:
Red Leader drive
The pump pressure is supposed to be about 52 to 58 psi.
Î dont know but there is fuel exit by the valve
The pump is new
The fuel is not coming out the injectors
It may be that the ECU is faulty. I had the opposite where too much fuel caused car not to idle. New ECU fixed it.
Auto electrician used oscilloscope? To view behaviour of ECU
Check the throttle cable isn't binding.
If the throttle is open the injectors are cut off.
Red Leader drive
Any fault codes in Protune II?
M3W, now!!!
JVS Offline
Rectifier Could be going bad ?
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
