8 members (IcePack, Alan Patterson, Vansrv6, aerotaff, Ritchie B, Image, Ncik P, BLUE+4),
371
84
Topics49,851
Posts837,443
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
I changed the fuel pump for the second time last week And after the Mtw started. I try starting it today without succes. There is fuel going out by the valve between cylinders but there is No fuel inside the cylinders .
Posts: 582 |
What is the pump pressure?
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
If there is fuel coming out of the injectors then it could be the cam belt sprocket has worn and the cam timing has slipped. This is what happened to mine. You can quickly check by seeing if the alignment holes are still OK:
Red Leader
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
The pump pressure is supposed to be about 52 to 58 psi.
Î dont know but there is fuel exit by the valve The pump is new The fuel is not coming out the injectors
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
It may be that the ECU is faulty. I had the opposite where too much fuel caused car not to idle. New ECU fixed it. Auto electrician used oscilloscope? To view behaviour of ECU
Check the throttle cable isn't binding.
If the throttle is open the injectors are cut off.
Red Leader
Posts: 400 |
Any fault codes in Protune II?
M3W, now!!!
Posts: 462 |
Rectifier Could be going bad ?
JV Sclafani Boca Raton, FL '13 M3W Metallic Orange Pearl 128CI Steered by Empire - Riding on Ohlins
