3 members (Alan Patterson, RichardV6, Socalm3w), 345 guests, and 50 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Page 76 of 94 1 2 74 75 76 77 78 93 94
Draggin #431339 21/02/17 08:51 PM
Q
Q
You mean i should not drill the pipes I just removed..the cats are just after the flex joint, where the pipes clamp/connect ?
Q8morgan #431343 21/02/17 08:56 PM
its all up to you, and how loud you want it i guess.
I want to get the pipes cooler, but not go deaf, so I may do nothing, or I may perforate that first baffle.
kirkusblog.com
1952 Ford 8N
Q8morgan #431344 21/02/17 08:57 PM
When I did my pipes, I left the cats intact and removed all three baffles. The front most baffle is the most restrictive. I also added a garage56 air cleaner cover. I do not find it overly noisy and it runs much better!!
Q8morgan #431348 21/02/17 09:03 PM
Work from engine end drill out first disc baffle see what you think! work back from there....
Q8morgan #431426 22/02/17 07:08 AM
+1 Rolsmith
rolsmith #431427 22/02/17 07:39 AM
exactly what I did and car is bang on now
Superdry
76 Fizzy
Q8morgan #431447 22/02/17 09:36 AM
Q
Q
I did 2 holes in the cats & they were very easy..working on the rear baffles.but i couldn't find an extention so i used more than 1 pipe & they keep on breaking..plus i bought the screw hole from ace & they aren't doing the job well..i might use a metal pole & a hammer to break a hole in the rear baffle
Q8morgan #431463 22/02/17 11:55 AM
Q
Q
I did a quick start, couldn't really tell much difference..i removed the rear baffle & 2 holes in the cats....i need the best bobbins for the exhaust, i have the poly on but one is slipping..
Q8morgan #431554 22/02/17 03:07 PM
Q
Q
I removed the cats & rear baffle..it doesn't sound any louder on start..i will need a test run..
Q8morgan #431644 22/02/17 07:02 PM
Q8 The drilling only gets part of it. You may be still able to save the one you already did by drilling the perimeter. Hole saw is the only way. Do ALL the baffles, but leave the cats---S&S tech says the engine needs some back pressure for the electronecs. Your sweet ride will love you. OR go to Garage 56??
