0 members (),
196
95
Topics49,847
Posts837,389
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
The headlights themselves look better than the current ones in my opinion
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
I don't like it. F...Mainly, putting large lights there just flies in the face of good air-cooling common sense - with all that open air up there, why put them right in front of the cylinders? So I think they did the best they could, all things considered, but it's a compromise I personally will look to remedy immediately upon delivery. Also: dual headlights are not a requirement for motorbikes in the USA last time I was there... so why not offer a single cyclops light? With outrider "driving lights" as an option?
Posts: 2,539 |
I don't like it. F...Mainly, putting large lights there just flies in the face of good air-cooling common sense - with all that open air up there, why put them right in front of the cylinders? So I think they did the best they could, all things considered, but it's a compromise I personally will look to remedy immediately upon delivery. Also: dual headlights are not a requirement for motorbikes in the USA last time I was there... so why not offer a single cyclops light? With outrider "driving lights" as an option? If you read the article, but that was one of the suggestions. For some reason the government isn't buying it.
Posts: 306 |
I don't like it. F...Mainly, putting large lights there just flies in the face of good air-cooling common sense - with all that open air up there, why put them right in front of the cylinders? So I think they did the best they could, all things considered, but it's a compromise I personally will look to remedy immediately upon delivery. Also: dual headlights are not a requirement for motorbikes in the USA last time I was there... so why not offer a single cyclops light? With outrider "driving lights" as an option? If you read the article, but that was one of the suggestions. For some reason the government isn't buying it. Yeah their concern at that point was still the turn signal masking. Which I can slightly understand, but still that would just be a reposition of the turn signals not all of the headlights. To be clear, the points that the old headlight bracket mounted to are hardpoints for suspension, right? Just making double sure on that, hopefully brackets can still be had here state side after this debacle is in full effect.
Posts: 136 |
There will be tons of old style brackets available when all the US owners voluntarily get their cars upgraded to the latest lighting setup! 😂
1959 4/4 - sold 1957 +4 - sold 2017 M3W - sold
Posts: 306 |
Wonder if the electronics could handle running 4 full on headlights. I kinda like Mario's photoshop, if they're not obstructing the air flow to the cylinders too much.
Either way I've written to NHTSA inquiring how this makes driving at night safer. I wager no response will be had from them.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Why not mount the new lights higher than the cylinder heads. In line with the old lights.
Posts: 836 |
Why not mount the new lights higher than the cylinder heads. In line with the old lights. Probably to keep it out of the line of the driver eyes.
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Switch to LED's and the electronics would be fine. I switched over to the J.W. Speaker LED's for brightness and reduced amperage draw. More light and more power to play with.
Posts: 306 |
Switch to LED's and the electronics would be fine. I switched over to the J.W. Speaker LED's for brightness and reduced amperage draw. More light and more power to play with. True enough, standard halogens are 3.15/4.75 or so for low and high beams and the JW Speakers are 2/3. Very good point.
