7 members (GBpluseight, Zach, James B W, Pipmac, MJF, Grumpy2, Image), 432 guests, and 93 robots.
Sagging Hood
Topics49,859
Posts837,477
Page 7 of 18 1 2 5 6 7 8 9 17 18
Thank you for the correction, I think we all in to much of a hurry and don't check before posting . To your brother,I will do my hundred lines later if it's ok with you sir. cheers
I know what you mean about the pace of life. It's part of the appeal of the three wheeler for me that I can escape the hurry, if you get my drift.
crazy2 drive sunny
Update from Kh.
Emission testing being undertaken by at lest 4 testing stations as we speak. More long drive testing to be carried out.
Production delays are because of this. All U.S. builds have been moved up.
Exhausts have been built as per my drawings.
Wheel discs have been made in the U.S. Apparently, Awesome is an under statement.
I enquired if they would make them available to all. They are, at present, only going to make them available on a limited scale.
Draggin, when i know more i will let you know.
The new head light arrangement is only for U.S. compliance, so not needed for the rest of the world.
More later.
With luck it should be ready for the Albert Ball blat in May
Thank you John~
kirkusblog.com
1952 Ford 8N
pandy #432224 24/02/17 05:25 PM
Originally Posted By pandy
I have to say, I think for a M3W the Aero Leathers Barnstormer which Martyn Culling has recommended in the past seems to be the most suitable jacket. Being horsehide it is naturally waterproof......
I have an Aero Horsehide Barnstormer (without the shearling collar and what I like about it over the Bomber Jackets is that it is better for an open cockpit, with no shearling at the cuffs. But the stiffness and length of it can cause it to ride up a bit around your ears.
kirkusblog.com
1952 Ford 8N
This is the US Authentic Barnstormer jacket. No relation to the Aero, But so far this has been my "Go To"
https://www.flightjacket.com/barnstormer-jacket.html
its short and comfortable, seals tight to the waist and wrists, can be buttoned to the neck, and has a real neat retro look to it.
kirkusblog.com
1952 Ford 8N
Thanks Draggin.
The US Authentic Barnstormer Jacket is perfectly in-keeping with the M3W
It looks the part!
kirkusblog.com
1952 Ford 8N
