1 members (+8Rich),
364
82
Topics49,870
Posts837,667
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
Seems that the long rumoured deelopment of a Rotrex supercharger conversion for our engines has finally made the light of day in the new Hesketh Valiant SC motorcycle. Good figures - 210bhp and 217lbs/ft - which would make our cars fly, let alone a 2-wheeler at half the weight. Neat work too... Hesketh Valiant Supercharged Wonder how long our drive-line would last eh ?!
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Where to begin? Both compensator and transmission to be beefed up. Frame in front would need major upgrade. Front tires and shocks as well. Twice the horse power and twice the torque is no small thing.
I see this thing being used for drag races with an engine rebuild happening often.
But that's just me...
Posts: 1,642 |
One set of exhausts per climb. One chassis per event. One engine per month.
Posts: 836 |
Honestly for the amount that you would need to upgrade in order to keep up with the power increase; money could better be spent elsewhere. It all comes back to one thing; Weight loss. Less strain on parts, less wear/tear, some power output, but with gained performance. Aerodynamics would go a long way as well, but I doubt many would be up for that.
Posts: 213 |
And you need to get that power to the ground. I think our rear tire is just about at the traction limit with the power we now have.
Inge
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
I have a supercharged Miata. The 50% increase in horsepower and torque "enhanced" what was already there. I fear that essentially doubling the horsepower and torque of the M3W would overwhelm the remaining bits.
Posts: 104 |
I'm not sure I've seen any failures in the car that are power related - anecdotally speaking Stage 1 kit cars are no less reliable than standard cars for instance. Similarly I don't think the rear tyre has a traction issue (again even in Stage 1 cars) other than in first, so a bit a of scope for more power with a careful right foot in the low gears. That said, quite how fast you actually want to go in a M3W is another question.
I'd certainly be willing to have a go in a supercharged one and keep an open mind.
2012 G56 Stage 2 M3W 2007 Fiat Panda 100HP 1998 Lotus Elise (Cosworth Duratec) 1988 RF88 Van Diemen
Memories of a ride in an Opal Kadette which had a V8 dropped in. It was barely controllable and wanted to leave the ground. Soul who owned it finally rolled it to death but walked away. A match not made in heaven!
Posts: 37,435 Likes: 978
Posts: 37,435 Likes: 978 |
Just because you can doesn't always mean you should  . On the other hand why not  ..
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
maybe turn the boost down a tad! more usable .then lot of money to cut it off in its prime.....
