9 members (waikiore, John07, Guten, Julian BB, Morganmike, MJF, TalkMorgan, John V6, GrumpyPa),
300
50
Topics48,362
Posts813,306
Members9,215
Posts: 1,544 |
I think thats always been the Morgan mantra!!
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
I talked to Mark Leddington about this very issue earlier in the year.
You are right. No real interest in filling the orders.
Production is at capacity, without adding an extra shift to extend the working day they cannot make more...and to do this would require a major change to the organisation of the production side of the business. Also, it would need a new team of craftsmen to do the work. They have enough trouble training/finding people to replace retirees and leavers. So there is no realistic way they can go from 750 cars to 1000. And apparently no real interest in improving production techniques. If the body tubs were properly jigged and finished to a standard practically all other parts would be off-the-shelf, pre-made, pre-drilled and ready to fit with a minimum of adjustment. This would have the advantage of interchangeability in the case that new mudguards, cowls, or bonnets were required. As it is too much customisation is required for every car.
Posts: 14,009 |
But then that's the whole ethos of a coach built car Peter!
Posts: 5,109 Likes: 56
Black Rat Charter Member
Posts: 5,109 Likes: 56 |
But then that's the whole ethos of a coach built car Peter! Well said John. Peter you should be very happy with your Built by robots soulless Jaguar
But then that's the whole ethos of a coach built car Peter! Fine if I am having a one off special built but there is no particular reason for every mudguard, front and rear, to be hand fitted. There is no reason why the width, left and right, front and rear, should differ on every car. There is no reason why the gap under the windscreen between the bottom of the windscreen and the top of the scuttle should be a variable. The chassis is brought in from outside mainly pre-drilled and ready for assembly and,one would hope, accurately jigged. The mudguards, cowls, and inner mudguards, are all made outside and within the variations of three different mudguard widths there is no reason why they could not be pre-cut and pre-drilled for assembly. The major hand built component is the body tub. If the angle, height, and general form of the firewall and the top of the scuttle was accurately built to conform to a jig or pattern (this is the major challenge) everything else would fall into place. The bonnets could even be standardised. A further challenge could be getting the door openings jigged and equal so that every door could be the same. I'm not able to estimate how much time this would save on each car but I would guess more than a day. Costs would be reduced by standardisation and production increased without additional specialised staff. But then what would I know, I've never worked for a coach builder, so my thoughts probably have no validity.
Posts: 1,490 |
Damn...make me read 1,000 words and THEN tell me you're unqualified to render an opinion!😂
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
I suspect that the M3W is relatively standardised compared to its four legged siblings.
Tim
Posts: 90 |
Last I checked, we were talking about the 3 Wheeler, and the 3 Wheeler doesn't have any doors.
2017 Morgan 3 Wheeler -BRG Shark 2008 Lotus Elise California Edition -Red 2009 Land Rover LR2 -Black
Posts: 2,539 |
The 3 wheeler is basically assembled by morgan, i believe. I know they make the ash frame. Do they make anything else?
Last I checked, we were talking about the 3 Wheeler, and the 3 Wheeler doesn't have any doors. Typical TM thread drift. Previous posts were regarding increased production of 4 wheelers to meet the demands of the relaxed rules in the USA for "replica" models. Keep up at the back there
