4 members (Rog G, truckin-on, mph, Bunny), 287 guests, and 39 robots.
John V6 68
DaveW 64
+8Rich 61
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,073
Captain Morgan, IRWIN
Page 4 of 4 1 2 3 4
Originally Posted By Felix42
MWS wheel cleaning kit. Easy to use and works a treat
http://shop.mwsint.com/product_details.asp?id=163
+1
+2, great stuff also on alloys.
2025 MG ZS EV aka Trigger
SFG Offline OP
Thanks for all the tips. My wife still thinks I'm going to clean them in the kitchen sink, she'll be relieved.
SFG
2012 4/4 Sport
I know of at least one Morgan owner who cleaned Stainless wires in the Dish Washer. Not sure if his swmbo was aware.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
It wasn't me!
I have only done small parts in ours!
Shhhhhhhh!
innocent
Green & Grown Up
Green & Grown Up
Originally Posted By Stuart Green
What's the secret?
On the car, I use a fresh Hot Water wash with Autoglym Shampoo on my Stainless Wires.
After drying, following a thread on here ages ago, I use a Medium to Soft Bottle Brush, with the Long Wire Twist Stem and the handle cut off, in my Drill set a Slow Speed.
I Probably get 3 or 4 cleans from one brush but it slips in and out of the wider Spoke Gaps without jamming provided you get the angles right.
Also gets around the Centre Hub. Magic
I'm having a set of wheels made for me by Phil Hallewell. I had a long chat with him on the phone and we talked about cleaning methods. He told me that there really is no reason why a pressure washer could not be used. His advice was, check your wheels are sound and be sensible.
I know some will disagree but he makes the things and will have seen more wheels in his lifetime than all of us put together.
If using a pressure washer just think of the action and how to vary the spray. Similar to using a hose with an adjustable spraygun/nozzle.
I never use the high pressure vortex nozzle....simply to powerful.
The normal jet nozzle is adjustably for power so better to use. It can be set to power or soft at will. Also, by keeping back from the target even on power setting you can get a fine mist effect that doesn't concentrate on a small area.
I find the fine mist effect good for a presoak to soften bugs/dirt and at the end as a rinse.
Worst thing about using a pressure washer on wheels apart from getting behind lose paint/chrome etc.
Is soaking the brake pads and gluing them to the discs with rust.
Take your wheels off the car.
Mark - No Longer driving
GaB Offline
Absolutely! I learned the hard.
I washed the car, and put it straight back in the garage.
When I came to move it some days later, I couldn't understand why it was locked solid (I normally push it in and out by hand).
I had to run the engine and put it in gear to release the vice-like grip!
Glenn
2001 Blacktop 4/4 Corsa Red 'Archie'
I usually take the wheels off. Spray them with "Simple Green" a industrial strength detergent, let them soak and than use My electric pressure washer. As well as a long bristle brush on the wire wheels.
Button
Page 4 of 4 1 2 3 4
