1 members (Moggo), 270 guests, and 29 robots.
+8Rich 89
Topics49,841
Posts837,323
Christoph
Page 22 of 34 1 2 20 21 22 23 24 33 34
Some better photos I have taken this morning. Both sides brackets are cracked in the same place.
This really sucks.
1998 +8
SS Sport tuned exhaust
2013 M3W
Stage ll motor kit
Cats removed
Thanks for extra photos Planenut , I think.
( Depends if I find a crack ! )
Hi Ian
Sorry to hear about your latest discovery of yet another potential source of cracks.
I hope you can get it repaired quickly and efficiently without too much expense.
Have you let MMC know about this, and if so, what is their reaction?
Best regards
Keith
Not told MMC about this yet Keith, other than if they read it here? My warranty has long expired and I don't think it is a big enough job to trouble them with. I will probably weld it up myself and maybe add a bit more metal to the tab, in typical Morgan engineering solution style. This may be just an isolated case?
I was about to start fitting my nice new SPA oil temp and pressure indicator (thanks for all that info) but that will have to wait a bit longer now.
I had a quick peek under mine at lunch time , but couldn't see anything as the floor panels on mine carry on further rear than yours and obscure it except the face with the Allen head nut.
Not a quick job so left it for another day.
Mines a late 2013 by the way.
drk Offline
Like nippymog I tried to take a look under my 3W and I have an aluminum panel which cover the chassis brace. I can't see if my chassis is ok because I should remove the panel. Mine is a 2012 with 4100 miles on
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
I
I
checked my 2014 with 6700 miles, no cracks. My bracket looks slightly different, with a flatter offset, I think. I also don't recognize the white round dot in the frame, mine has an empty hole there.
Inge
😱 Warranty claim... your white fits have been vibrated off!!!
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
I would still let MMC know about it. The more complaints about the frames failings maybe they will do a better job of building it. I would think it would be a liability issue.
1998 +8
2013 M3W
Stage ll motor kit
Cats removed
