10 members (RedThree, hugo, Rex_tulips, DaveK, RichB, howard, RichardV6, lez, IcePack, Alan Patterson), 295 guests, and 31 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,332
Members9,215
Page 2 of 4 1 2 3 4
nick w #449279 16/05/17 04:21 PM
Originally Posted By nick w
Originally Posted By Georgie
Hi Stewart
I once had a 1938 series 1 with a seat bladder (you can still get spare bladders from Uncle Melvyn) so decided to go that route. Bladders are too big so used a couple of wheel barrow inner tubes - good quality ones, two cycle inner tubes, and two lengths of flexible plastic tubing.
Remove air valves from wheel barrow tubes, clamp on the tubing (about 12" in length. Take the cycle tubes and cut off the valve stems, insert the valve stems in the other end of the tubing and clamp.
Hey presto two simple and quick seat bladders. Wrap them in some rubber matting (there are some sharp edges under there) and insert under the seats, pump up until firm - Simple.
David 2001 4/4 4 seater
Sort of sounds like you end up sitting on a toilet seat! How do you fill the centre?
Nick
Nick, the width between seat sliders is only about 7" so the tube compresses into an oval shape, it's very comfortable. pantsdown
Stewart S #449292 16/05/17 04:43 PM
Sounds good.
Nick
Stewart S #449405 17/05/17 10:36 AM
Stewart,
If it transpires you have the fabric mesh and rubber combo webbing on your seat base and want to keep the car authentic, Melvyn Rutter sells a new sheet of the stuff for about £40, enough for two seats. I've just done my drivers seat, though it is a 1989 bucket type, not reclining like yours. I now sit about 2 inches higher...
Tomorrow'l do
1989 +4
2001 CL500
gsel #449418 17/05/17 12:10 PM
Originally Posted By gsel
Stewart,
Thanks for info
Stewart S #453778 07/06/17 06:18 PM
Well as there is no America's Cup racing on tonight, thought I would repair my car seat
Removed it from the Mog - that was a hard job - bolt heads spinning where it was inaccessible to get a spanner in but overcame it by jamming a metal file in the chair runner - you can see it's yellow handle in the photo
The reason for the saggy bottom is because the rubber mesh that forms the bottom of the foam (is it called webbing or a diaphragm ?) has split neatly in a straight line letting the foam seat padding come out
My idea for a fix is to put metal eyelets in each side of the spilt rubber and lace up like a shoe
Here goes (TM silence for a couple of hours)
Stewart S #453782 07/06/17 06:26 PM
Stewart, I found the same with my seat mount bolts spinning. I have a small Stilson style wrench that fitted into the channel and locked the bolts. When refitting I used socket head bolts so no spanner needed.
sospan #453783 07/06/17 06:29 PM
It's a reet pain isn't it ?
My tool set or knowledge isn't that comprehensive
Could have done with longer arms as well
Stewart S #453786 07/06/17 06:44 PM
Well so far so good
The eyelets are going in nicely
Stewart S #453787 07/06/17 06:49 PM
jbk Offline
Good luck with the repair Stewart, while you are at it, you might want to consider also reinforcing your lacing by criss crossing underneath the diaphragm with heavy fishing line (at least 200lb bs) as a belt and braces job? Might last a bit longer spreading the load a bit.
1993 T16 +4 Lancia Blue.
jbk #453789 07/06/17 06:56 PM
As an alternative to fishing line, you might want to try nylon strimmer line, that's what I used and it worked very well.
Page 2 of 4 1 2 3 4
