Morgan Aero 8
0 members (), 263 guests, and 43 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
Thats good news.
Peter J Offline OP
Formerly known as Aldermog
I was curious as to why the vacuum pump had 2 ports.
I found this on the web, which explains all.
Exhaust flap valve...I guess on a cross pipe linking the LH and RHS exhausts, the flap will close when in sport mode, or something. Any BMW expert here?
This is the front of the engine in an Aero chassis, the pump is upper left.
Complicated, isn't it?
Not at all surprised the bonnet, front bodywork and O/S wing had to come off.
Think Williams have taken more than the wings & cowl off wink
Incredibly complex engine.... I am always slightly boggled by who designs these things!
+8 4.8
Pleased to hear it is fixed.
Peter J Offline OP
And done a LOT of cleaning and polishing of bits not normally seen...almoist like new!! evil
Great news Peter - delighted for you.
Hopefully not to severe a hit on the wallet!!
And your smiles returned!!
Neil
Peter, thanks for the update. I've added this to my "ones to watch list", as I did the issue on the potential failure of side-exhaust bracket. Sadly, that one I have experienced, in-spite of taking mitigation actions.
Time will tell on Vac Pump.
J. Neil
I have seen a couple of cars with exhaust flaps. They were to divert the flow from the silencer normal route ( usually not straight) to a straight through alternative pipe. Purpose was to improve flow and noise. Not sure if a BMW is set up like that though.
Some car modders fit a flap valve to dump the ehaust out before the silencer box to the underside, cutting out a big part of the system.
Peter J Offline OP
Yes, the C43 has three valves...
One opens or closes a transfer pipe between the two sides and the other two divert the exhaust away from the rear silencer on each side.
This happens only in "Sport +" mode which, the handbook suggests, is not for road use... mad2
