6 members (Graham, G4FUJ, Pipmac, Lordofthewings, britmog, Ritchie B, TBM),
323
90
Topics49,859
Posts837,476
Posts: 938 Likes: 19
Posts: 938 Likes: 19 |
Does any forum member have any recommendations for supply of aluminium rear brake drums (Alfin type?) to fit a Plus 8.
Thanks for the link. That's a fair point you have made, and maybe money better spent on upgrading the front discs?
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
If you have alloys....why? They will be hidden. Do you race? If you are really chasing performance then perhaps. The brake upgrade I would be interested in is ABS. It is fairly easy to lock the wheels with standard brakes let alone upgrades. Perhaps a brake bias valve to fine tune front/rear braking as well?
Posts: 1,943 |
If you have alloys....why? They will be hidden. Do you race? If you are really chasing performance then perhaps. The brake upgrade I would be interested in is ABS. It is fairly easy to lock the wheels with standard brakes let alone upgrades. Perhaps a brake bias valve to fine tune front/rear braking as well? I agree. I have Datson Alloy Drums on My Wire wheeled DHC. Keeping them shiny is a B----.
Button
Posts: 14,009 |
Posts: 2,779 Likes: 5
Posts: 2,779 Likes: 5 |
Yes they do, I thought about them for my old MG TC where they are very visible and the finning looks great but on most later cars they are pretty much hidden. Not sure they add much otherwise. Nice though.
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
You could just modify the original brake drums by getting a machine shop to turning the outside diameter true and then get an alloy muff turned and bored undersize.
You then heat the muff up and place it on the brake drum. As it cools it contracts onto the brake drum. Done correctly, it will have the grip of death on it and if the brakes ever get hot enough to loosen the muff then you have serious problems with your brakes!
I've done this on my 1936 F2 racer (on Morris 1000 drums), a Douglas 90 Plus motorcycle and a Grand Prix New Imperial (to cure a problem with the spoke tension pulling the front hub out of round)
Arwyn
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
If you have alloys....why? They will be hidden. Do you race? If you are really chasing performance then perhaps. The brake upgrade I would be interested in is ABS. It is fairly easy to lock the wheels with standard brakes let alone upgrades. Perhaps a brake bias valve to fine tune front/rear braking as well? Alloy drums are about heat dissipation to avoid brake fade. As indeed are discs. Spirited road driving particularly with long down hills can give brake fade
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
