10 members (High Hamster, nick w, sezznowt, DCH, bmgermany, Alistair, teknome, Zach, Grumpy2, Montegue),
255
84
Topics49,859
Posts837,481
Posts: 47 |
Hi all,
Can someone help me before I drown.
I'm in Nordkapp and it's persistently raining. Have mopped floors a number of time. Am getting around a 1/4 inch of water in foot wells and struggling to find where it's coming in.
I've sealed windows and put plastic bags under bonnet to stop water going down the heater intake but no better. Seems to be getting in with rain cover on but mine is not the one that goes down over the whole bonnet
Can't see where inside it's coming from but it seems to be on top of the carpets from around the clutch pedal area as a guess, but also in passenger side as well.
Any ideas???
Thanks
Phil
Regards
Phil
2001 4/4 Red
Posts: 37,416 Likes: 977
Posts: 37,416 Likes: 977 |
Sorry to hear this - worth checking the bulkhead grommets are sealing ok.
Posts: 228 |
I've heard the throttle cable can allow water in where it passes through the bulkhead.
Andy
2011, 4/4, 2.0, 75th Anniversary 2016, VW Polo GTI 2012, BMW 520d Touring
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
Screw holding on the bonnet hinge. Gaskets on the wipers arms.
Posts: 220 Likes: 1
Posts: 220 Likes: 1 |
gaskets around wind screen wipers is one. But after replacing mine there is still water coming through the foot well:-)
4/4 2 seater 2001 model
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
gosh sorry to hear of your flooding Phil
mine is a 2000 4/4 and i don't think I've experienced anything as bad as that
My first check would be all the seals from the engine bay through the bulkhead
water can track down in weird ways so it might not be immediately obvious
good luck
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Check the seam between the scuttle and the firewall. If you're getting a load of water in it could be coming off the front of your rain cover and going down between the front of the scuttle and the rear of the bonnet.
Posts: 2,583 |
Enjoy Nordkapp - it was blowing a gale when I was there.Don`t spend too much in the shop.Don`t forget to have a wee in the Northernmost Gents on the European Mainland!
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
A couple of years ago I had a problem with rain filling the ECU which is mounted in the passenger footwell by the glove compartment. The water had gone between the bonnet and the scuttle and tracked along the wiring harness through the hole in the bulkhead. I sealed the large gap in the rubber grommet with black waterproof silicone sealant.
Steve L.
1996 Plus 8 N22 MOG
Posts: 47 |
Thanks everyone.
I have had work done to the car before I left and the bonnet was taken off. I'm hoping there may be a connection here to the leak. The bonnet does not seem to be fitting down onto the tape as it was but I've covered the gap with the rain cover tonight. Had a look for evidence of water running down the bulkhead but nothing obvious, it does seem wet at the back of the heater air intake though.
I have plenty of daylight to sort things if it would stop raining.
Thanks again everyone
Did use loo at Nordkapp and thought I'd save my last £12 for a pint in hotel instead of buying souvenirs in shop!
Cheers
Phil
Regards
Phil
2001 4/4 Red
