Topics49,848
Posts837,407
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Anything special about changing the battery? My dealer when I bought it said not to do it myself as there might be some problem starting it after you do. 2013 model. Nothing special at all. Will start fine so long as the new battery is actually charged!
Posts: 1,338 |
I have replaced mine at home & all went well. I didn't notice anything different
Posts: 25 |
Greatly appreciate the info. You guys are the best.
Posts: 782 |
In case any other cheap-skates are out there, I replaced my Banner when it failed last year with an identical size and spec battery designed for ride-on lawn tractors and similar. Fitted easily but I had to find an adaptor as the pole contacts were in a slightly different orientation. Battery delivered was just over £30 and has worked flawlessly since.
Posts: 902 |
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Very neat! Lowdown weight too - good for the CoG!
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Excellent idea..!! Plenty of ventilation, so that's all good. What an opportunity to turn the oil tank 90 degrees and free up a whole load of space for luggage (or tools..!!) under there.
Posts: 6,538 |
Very neat good idea. Well done and thanks for posting those pics.
Neil
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
That's excellent redesign.
