3 members (+8Rich, stefan s, Luddite), 269 guests, and 98 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,426
Page 4 of 4 1 2 3 4
Reminds me, I have an HoE rod mirror to fit... smile
CBY Offline
It could sometimes happen. I suppose that if you don't introduce completely the filler, petrol flows in the breather and locks the breather. I have found a position, 4 o'clock and introducing gently the filler until the bottom, and beginning with a small flow and opening fully after, generally it works.
Regards
2005 PLUS 4
Warren Offline OP
Thank you!
Warren
2007 Plus 4, 4 seater
Warren Offline OP
Thanks to everyone for the useful suggestions and help; it is a real added bonus knowing there are so many of you out there to lend a hand!
I filled up at my local supermarket this week and much to my delight it couldn't have been easier. It was a very old pump and worked exactly as it should. I'm guessing the speed of delivery and sensitivity of the new pumps just don't work that well with Morgans. On the most part I shall now been fine and will just keep an eye open for old petrol stations when I travel further afield!
Loving my Morgan a lot!
THANK YOU ALL AGAIN! Warren
Warren
Formerly known as Aldermog
My experience, for what it is worth is as follows:
1. Pump delivery is an issue, it seems that some pumps "froth" the fuel more than others. The frothing of gasoline is largely due to the additives added by the various suppliers, all are very different.
2. The flap valve must be in the 12 O'Clock position. Even then with some fuels filling up is a real pain.
3. I use premium grade fuel, my preferred supplier is Shell, simply because irrespective of site it seems that I can fill up almost as quickly as with the Merc. BP is OK, tends to be a bit slower. Tesco is a supplier of last resort. I have, on a number of occasions, given up after putting 5 to 10L in and then gone elsewhere.
Why are Morgan's so sensitive? I think it is because the filler is so close to the tank, so foaming really causes a problem. On the Merc I measured the distance from filler to tank, which is under the back seat, it is almost 60cm. The Plus 8 is 20cm.
So, my conclusion is that the blowback is a "characteristic" of the design of the Trad Morgan coupled with the nature of modern fuel and the emission controls that stop fuel vapour escaping.
Time to go back to filling from These Cans
Or?
Warren Offline OP
Nice cans!
Warren
Hi Warren,
I'm a Moggie newbie as well and do have the same difficulties in refueling the car. I haven't found my modus operandi so far.
Also, my retailer advised me not to fill up the tank completly. Otherwise a charcoal filter, which is used to filter gas vapours, might get wet. Subsequently the Moggie's electronics might be confused and starting of the engine will be inhibited. However, I haven't experienced this not yet.
Nick Burns
2017 - 4/4 Two Tone Green 80th Anniversary Edition.
Page 4 of 4 1 2 3 4
