2 members (+8Rich, Pittsartist),
171
59
Topics49,863
Posts837,544
Posts: 15 |
The ignition warning light comes on intermittently -- on my 1984 4/4. I have checked the visible connections from the alternator and they seem OK -- the battery is OK -- the voltmeter shows 13volts when running -- the car runs OK at present. I can't see any other option but to replace the alternator which is only 6 years old. Has anyone got any other ideas please ?
Posts: 22,362 Likes: 353
Posts: 22,362 Likes: 353 |
If its a typical Lucas ACR alternator of the period, I recall they had a separate diode in the warning light circuit. So you may get a warning light but it may still charge properly. An auto electrician may be able to repair it.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
You can buy a new one for about £60. https://www.google.co.uk/url?sa=t&so...UoR6QZlHmiGzl8w It might help running through the diagnostics here.
1972 4/4 2 Seater
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
Should be higher than 13v when charging....time for new alternator at £60. have you checked the running voltage across the battery terminals with a multimeter? Don't trust smiths instruments to be accurate!
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
A good alternator should be chucking out about 14.4volts offload.
As well as the alternator have the battery load tested if the cells are in a poor state they can cause odd symptoms.
Oh and it's a mog check the state of the connections at the chassis
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Have you checked the belt and the pullies? Had a similar fault on a Kent engine which turned out to be the spot welded bottom pulley breaking up which caused the belt to slip but without the tell tale screeching noises!
Arwyn
Posts: 15 |
Thanks for all your suggestions I also emailed Peter Ballard -- he is the CVH Tech Services specialist listed in Miscellany. He suggested check battery and earth connections, which I did and found corrosion on +ive terminal post --- cleaned everything up and tried a run -out --- seems to have done the trick -- light now stays out
