3 members (Julian BB, Ian B, ScotiaSteve), 432 guests, and 95 robots.
+8Rich 84
Topics49,860
Posts837,484
#474708 30/09/17 07:48 AM
Just checked oil level on my 2015, I had waited 10 mins after running it up, there was a little bit of foaming on the surface, the oil level was ok, but is the foaming indicative of a problem? I have'nt noticed any previously. Warranty expires in a month's time!
0000oooooooo
tonyw123 #474711 30/09/17 08:06 AM
Is it milky coloured? This might indicate some moisture in the oil but might just be condensation if it does not get long regular run outs.
Many years ago I changed the head gasket on a Montego as the dipstick and filler were full of milky foam. Then I found out it was a trait of this type of engine and not the head gasket.
tonyw123 #474713 30/09/17 08:19 AM
Not really milky and not a lot of it, weather bad here but will take for a good run asap and check again, must admit it has'nt had much useage later but did have 60 mile run on Thursday.
0000oooooooo
tonyw123 #474716 30/09/17 08:27 AM
When was the last oil change? what oil? the water if in the engine will be sitting at the bottom of the sump until its mixed buy the action of the pump and engine movement. If the car is not 'run up' to operating temp the moisture will accumulate inside the engine. If run up to operating temp then the moisture will evapourate. Keep an eye on water levels in the cooling system, only remove cap when engine is cool!
Triumph Herald 1969 13/60
Morris 1970
BuyBritish #474725 30/09/17 09:32 AM
There is no cooling system with water in it on the Three Wheeler, as it is built using the KISS philosophy. KISS makes sure almost nothing can ever go wrong. smile
tonyw123 #474743 30/09/17 11:53 AM
As it is a dry sump engine I would surmise that the oil pump gulps whatever vapor is in the engine as well. That would lead to foaming.
tonyw123 #474750 30/09/17 12:56 PM
some cavitation is normal, my Harley did the same thing
kirkusblog.com
1952 Ford 8N
tonyw123 #474755 30/09/17 01:15 PM
The oil does get fairly frothy after a run - Once again I've inspected the oil following this and it's perfectly clean, functional, just frothy.
Changing the oil regularly is a given.
tonyw123 #475093 02/10/17 03:01 PM
I've had the same experience as Mark H, and agree, regular oil changes are essential. Does seem to muck up faster than I would have expected.
