Topics48,341
Posts812,992
Posts: 2,356 Likes: 2
Posts: 2,356 Likes: 2 |
 Between tanks Just have a look if you smell fuel
Posts: 3,658 Likes: 48
Posts: 3,658 Likes: 48 |
Not good.
Is this the approx 1 inch pipe that connects the two fuel tanks?
Red Leader
Posts: 712 Likes: 8
Posts: 712 Likes: 8 |
Nobody can say that you get bored with owning a M3W :
Posts: 1,670 |
It's yet another inspection point.
25 mm you Only need 80mm x 2 Just another point to Check why feeling bored? It s normal Morgan mind
Posts: 30 Likes: 1
Posts: 30 Likes: 1 |
GOOD GRIEF! And the rest of the hose looks "poor"; checked and cracking?!
I would replace with fuel injection spec'd hose; two plys of weave molded in the rubber.
Ron Davis 1986 +8 "Flapper" CanTab #1
Posts: 1,363 Likes: 11
Posts: 1,363 Likes: 11 |
When I had the frame replaced they took the time to go over everything. Fuel lines and even oil lines were replaced. All needed it. On a five year old car...
Posts: 329 |
is 25mm the diameter of the fueltank "exit-pipe" or the diameter of the rubber hose (80mm length)?
Posts: 329 |
you mean the aluminium pipe running underneath the bevelbox has a diameter of 25mm?
