7 members (IcePack, Cerberas, hugo, Montegue, John Wilcox, Ricosan, Paul F), 142 guests, and 86 robots.
Sagging Hood
Topics49,858
Posts837,465
Just as precaution...I'm planning to replace the the original motorcraft HT coil fitted on my 1974 4/4. I was just thinking of using a standard Lucas dlb 102 (not sure if that is correct?), but does anyone else have a recommendation for supplier or spec?
btw - I'm not looking to add a sports coil as the engine is standard, and still using points ignition. I might look at electronic in the future though...
What do you think?
The DLB105 is the one I fitted to my car approx 15 years ago and never had a problem with it. In fact, improved starting and idling.
Cheaper than a DLB102 as well!
Kind regards
Arwyn
Have you given any thought to converting to electronic ignition. I replaced the distributor and coil with Pertronix products on my 79' 4/4 1600GT. They work well in my opinion. Also replaced the wires with updated ones.
I have done similar but still have the coil and ballast.
I changed my coil a while ago to DLB105 - many suppliers on the web.
http://www.aldonauto.co.uk/ignition/distributors/lucas-xflow-distributors
I went for an Aldon electronic distributor with their Flamethrower coil which has run flawlessly for the last 15 years.
1972 4/4 2 Seater
Glad to hear. I just updated mine a few months ago. I was hoping it was a good, long term investment and my Flamethrower looks like the original coil. Thanks,
