2 members (jim109b, BLUE+4),
254
72
Topics49,851
Posts837,442
Posts: 1 |
Just as precaution...I'm planning to replace the the original motorcraft HT coil fitted on my 1974 4/4. I was just thinking of using a standard Lucas dlb 102 (not sure if that is correct?), but does anyone else have a recommendation for supplier or spec?
btw - I'm not looking to add a sports coil as the engine is standard, and still using points ignition. I might look at electronic in the future though...
What do you think?
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
The DLB105 is the one I fitted to my car approx 15 years ago and never had a problem with it. In fact, improved starting and idling.
Cheaper than a DLB102 as well!
Kind regards
Arwyn
Posts: 20 |
Have you given any thought to converting to electronic ignition. I replaced the distributor and coil with Pertronix products on my 79' 4/4 1600GT. They work well in my opinion. Also replaced the wires with updated ones.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Have you given any thought to converting to electronic ignition. I replaced the distributor and coil with Pertronix products on my 79' 4/4 1600GT. They work well in my opinion. Also replaced the wires with updated ones. I have done similar but still have the coil and ballast. I changed my coil a while ago to DLB105 - many suppliers on the web.
Richard 1976 4/4 4 Seater
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
Have you given any thought to converting to electronic ignition. I replaced the distributor and coil with Pertronix products on my 79' 4/4 1600GT. They work well in my opinion. Also replaced the wires with updated ones. I have done similar but still have the coil and ballast. I changed my coil a while ago to DLB105 - many suppliers on the web. http://www.aldonauto.co.uk/ignition/distributors/lucas-xflow-distributors I went for an Aldon electronic distributor with their Flamethrower coil which has run flawlessly for the last 15 years.
1972 4/4 2 Seater
Posts: 20 |
Glad to hear. I just updated mine a few months ago. I was hoping it was a good, long term investment and my Flamethrower looks like the original coil. Thanks,
