5 members (Socalm3w, Montegue, +8Rich, Hamwich, TalkMorgan), 398 guests, and 84 robots.
Sagging Hood
Topics49,858
Posts837,463
Just as precaution...I'm planning to replace the the original motorcraft HT coil fitted on my 1974 4/4. I was just thinking of using a standard Lucas dlb 102 (not sure if that is correct?), but does anyone else have a recommendation for supplier or spec?
btw - I'm not looking to add a sports coil as the engine is standard, and still using points ignition. I might look at electronic in the future though...
What do you think?
The DLB105 is the one I fitted to my car approx 15 years ago and never had a problem with it. In fact, improved starting and idling.
Cheaper than a DLB102 as well!
Kind regards
Arwyn
Have you given any thought to converting to electronic ignition. I replaced the distributor and coil with Pertronix products on my 79' 4/4 1600GT. They work well in my opinion. Also replaced the wires with updated ones.
I have done similar but still have the coil and ballast.
I changed my coil a while ago to DLB105 - many suppliers on the web.
http://www.aldonauto.co.uk/ignition/distributors/lucas-xflow-distributors
I went for an Aldon electronic distributor with their Flamethrower coil which has run flawlessly for the last 15 years.
1972 4/4 2 Seater
Glad to hear. I just updated mine a few months ago. I was hoping it was a good, long term investment and my Flamethrower looks like the original coil. Thanks,
