Topics49,863
Posts837,548
Posts: 1,562 |
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The K&N filters also have the bonus of having a locking wire hole for that extra bit of security.
Posts: 1,671 |
What about the reusable filters available for HD - I've got one of the same type fitted to my GTS1000 -
Posts: 1,562 |
Postscript In the period I could not get the filter off, I found this removal tool, which has just arrived in the post. I mention it as many sizes are available and it would be very easy to order the wrong size. Although I have not used it yet , it seems to be a perfect fit and very sturdy, the code on it is 905 https://www.ebay.co.uk/itm/13mm-Square-Drive-15-Flutes-Cap-Style-Oil-Filter-Wrench-73mm-Inner-Dia/191682964055?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2648
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 582 |
I believe this oil filter business has been discussed before. Please check the S&S website as to WHY you should be using an S&S filter rather than anything else if you want the best for your engine
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
I believe this oil filter business has been discussed before. Please check the S&S website as to WHY you should be using an S&S filter rather than anything else if you want the best for your engine At £16.20 from Matts Machine Mart why use anything else?
Red Leader
